Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Inline pump, is it for me (boltons, wet kit)
Old Jan 5, 2007 | 04:35 PM
IgorT.455/406's Avatar
Hey guys,
For a full bolton minus cam (300rwhp) car and a NW Wet kit (max 125 setting), could i get away with using a healthy stock fuel pump plus an inline booster pump? If so, which booster pump and where to put it?
OR, should I skip this alltogether and go with a racetronix 255 intank setup.
Want a couple of options.
Thanks guys,
Igor.
Old Jan 5, 2007 | 04:49 PM
2000GTP's Avatar
I would skip it altogether and get the Racetronix in-tank setup.
Old Jan 5, 2007 | 04:58 PM
mdacton's Avatar
I would do the intank also, never been a fan of in-line stuff
but I have never had one either
Racetronic thing looks to be a good deal, I just did a walbro/BBK 255 It works fine
Old Jan 5, 2007 | 05:25 PM
Thanks guys,
Anyone with an inline setup?
Old Jan 6, 2007 | 12:04 AM
OBE1 95Z28's Avatar
I've run it both ways; both work but I believe the upgraded in-tank pump setup is cleaner.
Old Jan 6, 2007 | 12:20 AM
What pump did you run and where if you dont mind me asking.
Thanks.
Old Jan 6, 2007 | 07:25 AM
rskrause's Avatar
Moderator
I would use the stock pump. I think it will be adequate. Maybe a voltage booster (Boost-a-Pump) or equivalent for insurance.
Rich
Old Jan 6, 2007 | 11:31 AM
Rich
That's what I had as an option too. Just not sure what BAP to get or where. ANy ideas?
Old Jan 6, 2007 | 04:31 PM
rskrause's Avatar
Moderator
Only one I have used is the Kenne Bell, which worked fine.
Rich
Old Jan 6, 2007 | 05:36 PM
THANKS!
I checked it out on their website, looks good, but where do I buy one? Any clue?
Thanks.
P.S. NEVER MIND, guess can buy it from them direct.
THanks!
alphaauto
Jan 23, 2015 07:42 AM
JamesN1830
Sep 11, 2002 10:57 AM
rje
Sep 9, 2002 12:35 PM
ezcheeze15
Aug 26, 2002 01:28 PM
ezcheeze15
Aug 8, 2002 12:27 AM
