Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
injectors i should run...???
Old Jun 21, 2011 | 10:31 AM
manfire1987's Avatar
Ok maybe I am making this more of a hassle than it should be but I don't want this build to go wrong .... I have seen the on line equations to figure out fuel injectors size but not sure exactly if that's true as I really don't know what kinda flywheel horse power I should or could expect here is the build also in signature ...... all bolt ons ... cc306 cam ported heads "similar to le2" 1.6 rr what you guys think?????
Old Jun 21, 2011 | 07:13 PM
Re: injectors i should run...???
You could be around 450HP at the flywheel, and "get by" with 32 #/HR injectors. But I'd use a 36 #/HR injector, to cover you up to about 515HP. There is no downside to a larger than required injector, as long as it isn't so ridiculously big that the PCM can't turn it down to the tiny pulse width required for idle. But the stock PCM seems to be capable of handling 42's with no problem.
Old Jun 21, 2011 | 09:58 PM
So needless to say running 42 lb injectors for this build is to much??? That's Wat I purchased lucas 42lb...
Old Jun 21, 2011 | 10:34 PM
I think I already answered your question. You will be good for 600HP.
Old Jun 21, 2011 | 10:37 PM
So bigger than what I need but I will be ok... thanks for the help
Old Jun 24, 2011 | 06:05 AM
RobsWS6's Avatar
42's should be fine. With any injector though, tuning is a must.
I have a set of 42's I'm selling. They are used but had them flowed/cleaned but haven't put any fuel in since. Comes with a flow sheet. PM if interested.
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
