Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
injectors
Old Feb 1, 2007 | 09:38 PM
12345678910's Avatar
injectors
does anyone know if aftermarket ls1 injectors will work on an lt1 thanks
Old Feb 1, 2007 | 09:48 PM
OBE1 95Z28's Avatar
Yes, physically they're the same size; you'll need to check their flow rating for your application.
Old Feb 1, 2007 | 10:56 PM
The important thing to know is that an LS1 fuel system operates at 4bar (58psi), and the stock LS1 injectors are flow rated at that pressure. Hence, a stock 28#/HR LS1 injector running in an LT1 fuel system operating at 3bar (43.5psi) will only flow 24#/HR.
If they are aftermarket injectors, you have to ask the manufacturer what pressure they are flow rated at, to see how they would perform in your LT1 fuel system.
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
