Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
injector size?
Old Jun 14, 2007 | 01:13 PM
horse-power400's Avatar
injector size?
Which injectors should I run On my 383 build up it has ported heads flow around 260cfm, port matched intake, 58mm TB, CAI, LT's, 3in. True duals, cc306 cam I was thinking either 30 or 36lb. How much horse power can 30lb injectors hold? Thanks
Old Jun 14, 2007 | 01:51 PM
speedracer69's Avatar
I pretty much have the same setup. I'm running 42lbs injectors because I'm using the bottle aswell
Old Jun 14, 2007 | 03:40 PM
So 36lb. injectors won't be to much for this setup?
Old Jun 14, 2007 | 04:20 PM
cnorton's Avatar
My car has run 9.70s with 36 pound injectors. With a proper tune you should not need to push the limit of the duty-cycle on those units.
Old Jun 14, 2007 | 04:21 PM
I'm no expert but i would say yes.
If your not going to us the bottle should be no problem
I would do the 36 just to be on the safe side
Old Jun 14, 2007 | 04:51 PM
how much does a good mail order tune cost and where is a good place to get one from? Will I be able to drive it without a tune for maybe a month or two?
Old Jun 14, 2007 | 06:02 PM
I had my tuned from pcm4less but have had nothing but problems.
Its best to tune it on the dyno not over the net
Old Jun 14, 2007 | 06:09 PM
Injector size is determined by your FLYWHEEL HP. For a normally aspirated engine multiply your estimated flywheel HP by 0.07 to get in the ball park on injector size....
500 flywheel HP X 0.07 = 35 #/HR
450 flywheel HP X 0.07 = 31.5 #/HR
400 flywheel HP x 0.07 = 28 #/HR
That assumes a decent tune at 0.476 #/HR/HP BSFC and and 85% duty cycle. Going larger on injector size will not hurt you, as long as you don't get ridiculous and run into turndown problems that limit idle fueling. Many people have no problems running 42 #/HR injectors on street driven cars.
I'll move this to the correct forum.......
Old Jun 14, 2007 | 06:40 PM
Thanks that is what I was wanting to know.
HectorM52
Jul 30, 2017 11:46 AM
Fastbird93
Apr 9, 2016 07:01 PM
QuickSilver02
Apr 7, 2015 11:12 AM
drptop70ss
Mar 26, 2015 01:50 AM
