Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
injector cleaner
Old Jul 11, 2011 | 12:38 AM
twistedbowtie's Avatar
Question injector cleaner
i have a 1995 z28 camaro lt1. i decided to put injector cleaner in the gas tank the other day and put way 'way'' to much. it said 3 oz. for 10 gallons i prob. had 1/4 of a tank and put 10 oz .
my car acts like its out of gas even after filling up the tank. could this be because i put to much cleaner ?
im not sure because i just did a optispark replacement at the same time. the reason why i think its fuel is i started the car after putting the opti on and it ran fine but eventually it ran crappy my thought was it ran good until the old gas(without the injector cleaner) was out of the fuel line then started burning the deluted gas and want run right. is this possible? thanks guys
Old Jul 11, 2011 | 05:22 AM
Guest47904's Avatar
Guest
Re: injector cleaner
First change the fuel filter. You probably washed the gunk/film from the tank into the filter.
If it still runs crappy, lift the fuel rails and have someone crank it over while you look at the spray pattern.
Old Jul 11, 2011 | 09:47 AM
okay thanks ill try that
93 RedBird
Nov 15, 2015 08:24 AM
form94
Sep 23, 2015 07:30 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
plattted
West South Central
Sep 7, 2015 02:45 PM
