Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
igniton wiring help
Old Apr 4, 2011 | 05:14 PM
DTRJAR's Avatar
Unhappy igniton wiring help
ok so im trying to do a push button start on my car but need the igniton switch wiring diagram if some one can help me find it thank you
Old Apr 5, 2011 | 09:54 AM
bobdec's Avatar
Re: igniton wiring help
No printable schematic but...
Position B C2 Red wire +12 from battery (fusible link)
Position E C2 Brown wire +12 ACCY or RUN (RAP, radio, wipers, etc)
Position C C2 Pink wire +12 +12 RUN (Air Bag, PCM, injectors, MAP, MAS)
Position A C1 Orange wire +12 RUN ( ABS, fans, turn signals, HVAC, air pump)
Position A C2 Yellow wire +12 START (to Theft Deterrent Relay, starter solenoid, crank signal to SIR--DERM, clutch M6 or tranny linkage A4 switch)
You could disconnect Yellow wire then use C C2 or C C1 (+12 RUN) to feed the starter button, then +12 output of button to Yellow wire.
Old Apr 5, 2011 | 10:26 AM
There is a schematic on my site.
http://shbox.com/1/ignswschematic.jpg
Old Apr 5, 2011 | 11:00 AM
DTRJAR's Avatar
thanks guys
Old Apr 23, 2011 | 10:33 PM
DTRJAR's Avatar
need more help need pics of wiring and any help thanks
Old Apr 23, 2011 | 11:23 PM
DTRJAR's Avatar
It's for a 95 z
Old Apr 24, 2011 | 07:42 PM
DTRJAR's Avatar
Any one
surreybrad
Apr 22, 2015 06:40 AM
EdgarArmada
Apr 18, 2015 05:20 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Ryabut98
Sep 3, 2002 11:45 PM
kandied91z
Aug 6, 2002 01:18 AM
