Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
ICM failure
Old Jun 9, 2018 | 07:57 AM
KYWes's Avatar
ICM failure
I've had a regular problem of the ICM failing every couple of years.
This time when it failed I saw that one of the screws holding the ICM to the mounting plate had come out.
The threads were stripped not allowing me to tighten the ICM mounting bolt and these things really need the heat sink.
I decided to drill out the threads and use a through bolt to hold the ICM in place. It turns out that a 3mm x 30mm bolt fits well and the head of the bolt fits into the hole on the plate that mates against the head making the head of the bolt recessed so no mounting issues.
I used a washer, lock washer, and nut, applied the heat sink compound, tightened it down, and then reinstalled everything. We'll see if it lasts longer than two years.
BTW, at one time I did the mod of adding spacers under the mounting plate but later took them out, I don't remember why I felt I needed to remove them but may add the spacers back in to isolate the ICM assy from the head to hopefully reduce heat being transmitted from the head.
Old Jun 9, 2018 | 08:50 AM
Re: ICM failure
Have you been using heat transfer compound between the ICM and the heat sink?
Old Jun 9, 2018 | 09:16 AM
KYWes's Avatar
Re: ICM failure
Yes, it had the compound and I used it on this install.
Old Jun 12, 2018 | 04:26 PM
DrewHMS97SS's Avatar
Re: ICM failure
Try doing the spacer mod. Basically take the heat sync off the head, then add 2 washers to each side so the heat sync is not directly in contact with the head. For better thermal performance, use a higher end compound for computer CPUs. My personal favorite is Arctic Silver.
Old Jun 12, 2018 | 05:09 PM
KYWes's Avatar
Re: ICM failure
I tried the spacer mod but it didn't go well but I forget why. I used Artic Silver this time as I had some left over from a computer build. We'll see how she holds.
lt1_forever
Oct 4, 2004 09:44 AM
ibanez6rg
Jan 14, 2004 11:51 AM
reuter
Oct 12, 2003 05:24 PM
91RS5speed
3rd Gen / L98 Engine Tech
May 10, 2003 12:33 PM
