Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
how to check for bad fuel regulator?
Old Jul 8, 2007 | 12:21 PM
Wishmaster's Avatar
I think im having an issue with a leaking fuel pressure regulator....its off the car.....how can I check to see if its bad? or if it leaks?
Old Jul 8, 2007 | 01:03 PM
Put a vacuum pump on the vacuum compensation port and see if it will hold a vacuum. Try holding it at about 20"Hg.
Old Jul 8, 2007 | 01:28 PM
Wishmaster's Avatar
your gonna have to help me out here.....do you mean hook a vaccum up to the end where fuel goes in? and what do I do with the other end? plug it?
or the other way around?..put the vaccum up to the end the fuel comes out and plug where it goes in?
Old Jul 9, 2007 | 03:54 PM
mdenz3's Avatar
There should be a port on the regulator where a vacume line goes (will be a small bubber line that goes from the intake manifold to the fuel pressure regulator). That is where you should hook up the vacume tester.
Old Jul 9, 2007 | 04:47 PM
Wishmaster's Avatar
I called Kirban Performance where I got the regulator and he was very helpful. He told me that all a reg is nothing but a spring and diaphram...and even if there was a hole in it and would not hold pressure the car would have a very hard time firing up if at all.......says he is 100% percent sure that my problem is my injectors but if for some reason it was the then he would replace it..
Old Jul 9, 2007 | 04:53 PM
mdenz3's Avatar
Glad to hear Kirban was helpful to you. What exactly is the problem you are having?
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
