Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
High or Low pressure walbro?
Old Nov 30, 2008 | 11:48 PM
LT1 POWR's Avatar
I'm in the market for dual walbro pumps and need to know which one to get for my application(procharged 383 700+rwhp). Does the GSS 340 come in a low and high pressure pump? The company I'm buying from offers both. I'm using an Accell AFPR and most likely low impedence injectors(probably 96 lbers)
Old Dec 7, 2008 | 02:56 PM
OBE1 95Z28's Avatar
If you plan to run the stock fuel pressure, both pumps will meet your needs. The high pressure pump will maintain the same flow rate at higher fuel pressures.
RUENUF
Mar 13, 2016 03:39 PM
Jan 23, 2015 01:13 PM
My94RedZ28A4
Aug 11, 2002 10:04 PM
funina91ss
Aug 6, 2002 11:20 PM
