Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Help with hooking up Evap fuel vapor canister.
Old Jun 10, 2008 | 01:24 AM
crazypurgatory's Avatar
Question Help with hooking up Evap fuel vapor canister.
On my 1997 Camaro Z28 I had to replace my fuel pump and my fuel vapor canister lines came off.
I found this on Shoebox's page http://shbox.com/1/evap_system.jpg
But I can't tell how the lines hook up
I need to find out where all the lines go I believe there are "three"?
Thanks for any help you can give me.
Old Jun 10, 2008 | 07:28 AM
Did you scroll down on that pic to see the canister and the three lines labeled?
Old Jun 10, 2008 | 10:49 AM
oops OK so one goes to the tank and one goes to the line.
I guess the third line goes up to the engine.
Thanks,
Old Jun 12, 2008 | 10:52 AM
OK let me see if I got these lines right.
The purge tube gets connected to the metal line next to the fuel return.
The Tank tube with the valve on it gets connected to the tank.
And the air tube gets connected to nothing open to the air?
It looks like it's time to buy a service manual.
Thanks,
Old Jun 12, 2008 | 07:26 PM
There is a vent line under the car, attached to the differential at one of the brake pipe clamps. It might go to that, but it's hard to tell where anything goes under there for lack of space.
Old Jun 12, 2008 | 09:01 PM
Yea I see that one.
From what I can tell the middle one stays open becauase thats where it pulls air through that port.
Thanks,
Chris G.
Old Jun 14, 2008 | 01:04 PM
I have no idea where this line goes to.
http://www.flickr.com/photos/crazypu...49252/sizes/l/
One line comes off the canister and goes down by the return line.
One line comes off the tank and gets connect to the canister with the valve on it.
There is one thats on the gas tank that has a plastic bell on it that stays on the tank.
But I have this third hose I have know idea where it goes it must go on the fresh air port on the canister but where do I run it over the top of the tank?
If I do that it will get pinched off when I put the tank in.
The only thing I can think of is putting it on the rail of the tank where all the other lines are at but I just don't know.
I don't want problems after I put the tank up and have to pull it down.
thanks,
Old Jun 16, 2008 | 03:59 PM
Question
Is there nobody that has my answer?
Old Jul 16, 2008 | 07:31 PM
v7guy's Avatar
There is room for those lines, but it is very tight. The lines run up one of the depressions in the tank over to the filler area. I accidentally pinched one of them last time I had the fuel tank out and had to wiggle it into the right groove on the tank to keep it from happening again. A bit of tape helped out.
Old Jul 16, 2008 | 07:42 PM
Thanks I just left it some where on top of the tank or on the side rail of the tank.
In any case I can pull the line out so it's not pinched.
I figured it just sits there.
Old Jul 17, 2008 | 12:11 AM
LJM97Z's Avatar
Yeah, there is a line that just goes knowwhere from the sending unit, it just goes along the rail to open air, i'm sure its just a vent tube, the pixture you showed looks like it.
Old Jul 17, 2008 | 10:02 PM
96SilverRam's Avatar
Good info in this thread.
CaptainObviousI
29
Apr 29, 2021 10:35 PM
HectorM52
Jul 30, 2017 11:46 AM
mr28
Apr 20, 2016 05:44 PM
Magenta_Hearts
Mar 22, 2015 03:36 PM
Brady
Jul 29, 2002 10:30 PM
