Help with fuel system I think?????
Hello everyone, i have had my 94 LT-1 running for about 2 days now. When the motor is cold it starts right up with no problem at all. After running the motor it seems to run very good except i think it is running rich judging by the exhaust fumes at the rear of the car. After the motor has been ran and is warm it does not want to start right back up like when cold. It acts like it is out of time or something. I know these cars use the Opti Spark system but dont know a whole lot about them. Can anyone give me some recommendations as where to start trouble shooting or any ideas as to what it might be? The motor supposedly just has a little over 1k miles on it according to the previous owner. Thanks!.....
Re: Help with fuel system I think?????
Have you scanned it for codes? Sounds like you may have a problem with the coolant temp sensor. It's telling the PCM the engine is cold, so the PCM richens the mixture for a cold start. If it's actually cold it starts fine. As the engine warms up and the coolant temp sensor doesn't read "warm" the engine runs rich. Try to start a warm engine when the CTS reads cold, the engine may not start
Check the sensor..... it's the one on the water pump housing. Rob/Shoebox has a guide to testing the sensor:
4th Gen LT1 F-body Tech Articles
If you have access to a real-time scanner, or scanning software, take a look at the coolant temps the PCM is receiving.
Jul 4, 2005 05:00 PM
