Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
GM stock fuel pump defective in 95 LT1
Old Apr 6, 2012 | 05:59 PM
  #16
96capricemgr's Avatar
Re: GM stock fuel pump defective in 95 LT1
Stock wiring for basically everything is marginally sized, small amounts of corrosion, dirt even just loose pins in the wiring plugs can all conspire to each lower voltage a little. I would begin with inspecting every connection in the fuel pump circuit and the cable to the underhood fuse/relay block. Check the fuel pump ground too.
The fact Fred and I called this as an electrical issue right away while dealerships just kept swapping pumps should tell you at lot about how little "technicians" understand as compared to enthusiasts. "technicians" are rarely capable of diagnosing much unless the computer gives them a code.
Old Apr 9, 2012 | 08:10 AM
  #17
lacarpe's Avatar
Thanks for the info. I start checking the why the volts are low.
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
HectorM52
Jul 30, 2017 11:46 AM
Gtpguy
Jan 26, 2015 04:50 PM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
ANDYZ28
Dec 29, 2014 09:13 PM
