Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Fuel System Upgrade for Nitrous Options
Old Sep 19, 2010 | 11:03 AM
revis_jonathan's Avatar
Car Info:
97 LT1 SS 355 (GM847 Cam, Ported Stock Casting Heads 2.02/1.60 valves)
11:1 CR, Forged SRP Pistons, Forged H Beam Rods (Eagle), Forged 4340 Crank (Eagle)
Power:
~360rwhp/370rwT
Fuel System:
42lb Racetronix Injectors
255lph Ractronix FP w/ optional harness
Metco AFPR
All other fuel components stock
The problem:
Currently installed is NOS Dry Kit. The problem with it is due to the fuel psi increase on activation (about 70-80psi) the fuel pump flow goes down below the required amount neccessary to run the nitrous kit.
See Link For Walbro 255lph Fuel Pump Flow vs Pressure Chart:
http://c4.ac-images.myspacecdn.com/i...a74f08921f.jpg
What do you think is the easiesr, best reliable option on a reasonable budget.
Solutions:
A - Change over to a wet kit
Con - Nitrous Backfires more likely
B - Install another fuel pump (Series or Parallel?)
Con - Removal of bucket (parallel) or noisy pump when in series
C - Install Boost-a-pump to boost fp voltage and flow during nitrous activation
Con - How will that high voltage affect the dependability of the pump in the long run?
D - Another viable option I haven't thought about?
Old Sep 19, 2010 | 04:16 PM
With a pump capacity of only 38gph (144 LPH) at 12.0V, its likely you are running out of fuel. You need the Walbro high pressure 255 LPH pump, which will flow over 200 LPH at 80psi. Another alternative would be an in-line external pump. You could use a boost-a-pump to raise the voltage to the pump, but I'm not sure you can gain enough that way.
Are you sure the Metco AFPR will work OK with the slipstream from the nitrous to boost the pressure? I had one of the first LT1 dry kits from NOS back in early 1995. I thought the inline booster pump was bad, and took the pump to the NOS shop to have it flow tested. Met spec (its a Bosch 208, that I am still using 15 years later). We traced the problem to the AFPR, and I don't remember the brand. Put the stock FPR back in, and the kit worked perfectly. Just a thought.
Old Sep 19, 2010 | 04:30 PM
I was under the impression that Racetronix's 255lph Intank Pump was a hi-pressure Walbro pump.
Old Sep 19, 2010 | 10:57 PM
I can't find a copy of the high pressure curve, but it flows a lot more than the curve you linked. This is the copy that is included on virtually every website that sells the Walbro 255 LPH pumps:
The Walbro high output in-tank electric fuel pumps are available in flow ratings of 255 liters of fuel per hour. These particular pumps flow significantly more fuel at higher pressure. For example, at 80 PSI the standard 255 lph pump will flow around 132 liters (35 gallons) per hour. At that same 80 PSI the equivalent HP (high pressure) fuel pump will flow over 210 liters (50 gallons) per hour.
I have no idea what Racetronix sells.
RUENUF
May 25, 2016 08:10 PM
bandit383lt4
Dec 21, 2014 09:12 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Jul 4, 2005 05:00 PM
