Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
fuel pressure check
Old Jun 12, 2007 | 07:43 AM
ZL1modified's Avatar
fuel pressure check
my car has been lacking power at WOT...
update:
fuel pressure @ WOT is 50 psi (40 psi @ idle) and my pressure bleeds down instantly when i turm my engine off...(i thought it was to slowly bleed down)
where should it be and how should i fix it... is it as simple as adjusting the regulator or is the problem more than that?
thanks to everyone for your help...
http://http://web.camaross.com/forum...d.php?t=525864
Old Jun 12, 2007 | 09:21 AM
BUBBA's Avatar
Stock FP between 43-46 at WOT (measured with the vac line off) deduct round 8 with vac line. Unless you have an adjustable regulator you won't be able to change it.
It may be running a bit rich at 50 which may cause some power loss, but you might look elsewhere, e.g. what is your A/F? Ideally, probably aound 12.9 to 13.1.
If you haven't had it tuned, you should at least have someone do a wide-band scan to see if you are running too rich. JMHO
Old Jun 21, 2007 | 10:01 AM
OBE1 95Z28's Avatar
You fuel bleed down issue when you shut the engine off is most likely caused by a faulty/dirty check valve in the fuel pump. It can also be caused by leaky fuel injector(s) or a bad fuel pressure regulator. This has have nothing to do with your lack of power at WOT, but it usually causes hard starting.
Old Jun 22, 2007 | 09:14 PM
MTL_Z28's Avatar
If the loss in pressure was gradual vs. instantaneous, would it be an indication as to the source of the loss of pressure? (ie check valve in fuel pump vs. a leaky injector(s) )
DirtyDaveW
Dec 1, 2016 05:37 PM
Alex Barnes
Jan 24, 2015 10:21 PM
nophix
Nov 30, 2014 10:26 PM
Jul 4, 2005 05:00 PM
Burn_Out
Aug 18, 2002 08:49 AM
