Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Fuel line removal...
Old Mar 22, 2009 | 03:52 PM
meangreenchevy's Avatar
how do you remove the rubber fuel lines inside the engine bay??? its a 97 lt1 i need to diconnect it where it goes into the shock tower
Old Mar 22, 2009 | 09:39 PM
The line runs continuously, from the metal fuel lines that end at the rocker panel, near the leading edge of the driver's door, all the way to the connections to the hard lines at the rear of the intake manifold. You have to disconnect them at the metal lines under the car, or at the hard lines. There is no intermediate disconnect that would allow you to remove them from the shock tower. The lines are plastic, not rubber.
Old Apr 13, 2009 | 06:59 PM
mzgp5x's Avatar
I have a 97ss. I removed most all of the stock fuel line except for the fuel return. The "silver" metal connectors that are assembled to the plastic line appears to be heat-swaged. Very difficult to remove from the plastic, and, I had to cut it loose. I machined new aluminum fittings to reuse the plastic line (tank fuel return). HTH. B.
HectorM52
Jul 30, 2017 11:46 AM
87Aerocoupe
Mar 20, 2015 01:23 AM
Jul 4, 2005 05:00 PM
91Bird305
Aug 5, 2002 01:39 PM
