Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Fuel injector pulse width
Old Jun 12, 2008 | 06:17 PM
mad95z's Avatar
Could someone explain to me why there would be a 1-1.5 ms difference in the pulse widths from the left to the right bank of my engine at idle?
In a 1995 LT1 Heads/cam combo. Racetronix 37lb injectors, PCM for less tune? They equalize during accelerating.
Old Jun 12, 2008 | 08:26 PM
The BLM's (long term fuel corrections) on one side are significantly higher than the other side. "Split BLM's" are not uncommon with a decent size cam or with an aftermarket throttle body. Or it may be a problem with misfires or an exhaust leak on one side, causing a "false lean" and driving the long terms up. If you are scanning it to see the pulse widths, you should also be able to look at the long term fuel corrections for Cell 16, the idle Cell.
AdsoYo
May 2, 2018 03:21 AM
daves91z28
3rd Gen / L98 Engine Tech
May 12, 2016 06:19 AM
MyfateZ28
Jun 19, 2015 03:42 AM
nophix
Nov 30, 2014 10:26 PM
Jul 4, 2005 05:00 PM
