Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Fuel gauge jumps around
Old Dec 23, 2006 | 05:40 PM
SS1156's Avatar
I did a search and did not find anything specific to my problem. I was driving the car today and noticed that the needle in the gauge was jumping around quite a bit. I know that the sending unit is a float design but the needle was moving too much. Do you guys think the sending unit is going bad? The car only has 56k on it. If I need to replace it, can I get one with a walbro 255lph pump already in it? thanks for any help you all can send.
Old Dec 25, 2006 | 11:34 AM
OBE1 95Z28's Avatar
The sending unit and the pump are separate parts that mount next to each other in the tank. Your problem may be a wire issue; Shoebox has a troubleshooting procedure here: http://shbox.com/1/4th_gen_tech2.html#fuel_gauge
Garcia5
Jul 7, 2022 06:51 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
jj71787
Jan 31, 2015 10:20 PM
ANDYZ28
Dec 29, 2014 09:13 PM
blac94Z
Nov 24, 2014 07:12 PM
