Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Fuel Gauge
Old Jun 11, 2008 | 03:16 PM
cblinkdude182's Avatar
Fuel Gauge
The fuel guage nearly caused me a heart attack today... I was driving down the feeder road and tried to pass somebody and my car started stuttering so I then slowed down and when I got to the light it was close to dying. So I turned into the gas station and my gauge was in between half and the E, but I filled it up anyway and ended putting 15.4 gallons in it, is that normal? Is it the guage or something else?
BTW car ran normal after I filled up with gas and when I filled it up it goes WAY past the F.
Old Jun 11, 2008 | 04:02 PM
Wow ok just called the guy who sold it to me...the gas gauge reads high so I guess that was it...
Old Jun 12, 2008 | 02:08 PM
rallysport92's Avatar
Does anybody know the cause of this?... Because I have the same problem but it was after I changed my fuel pump. Before I changed it everything was working fine. Please help!!
Old Jun 12, 2008 | 03:07 PM
EnFuegoZ28's Avatar
The tank is designed in a V type shape, so thats why it does that. When reading it assume a 1/4 tank less than it reads. F= 3/4 1/2=1/4, and so on.
Old Jun 12, 2008 | 04:24 PM
But this problem didnt exist before I changed the fuel pump...
Old Jun 16, 2008 | 05:44 PM
BTW is it accurate when you have the engine off?
Old Jun 24, 2008 | 10:25 AM
No it's not accurate even when the engine is off. I think I did something wrong or something got stuck but I dont wanna go through the whole monster process of changing the pump again.
Old Jun 26, 2008 | 01:46 PM
Casie's Avatar
Have you taken a look at the fuel sending unit. I have to replace mine because it shows over Full when there is 3/4 of a tank.
Old Jun 26, 2008 | 10:07 PM
Is that in the tank too?
Old Jun 26, 2008 | 10:14 PM
Angelis83LT's Avatar
the sending units are very very VERY delicate. takes nothing at all to fubar them. Hanging the float on the lip of the tank when taking the assembly out can screw it up. Other than that, GM gauges in f-bodies have always sucked. I am in the process of buy a fuel cell sending unit and sticking it the tank in my thirdgen. Sure i have to fab a collar for it to it fits.. but overall, it will actually work, and thats $50 vs $499.99 for a new sending unit, And the thirdgen does not even have a fuel pump on it lol. it's a mechanical.
But yea. fuel sending units from GM are pretty much junk. Removing it from the tank unless you a very careful and do it slowly can easily screw it up, making it a bigger piece of junk.
Old Jun 29, 2008 | 05:20 PM
IPrice's Avatar
+1
And +1 on the V Shaped tank reply as well.....
Does anyone notice how the cars stay full for like the first day you fill up, then the needle actually moves down to E as you drive???
I've only ran OUT of fast about three times in mine so that should tell you that, yeah, sometimes they aren't exactly perfectly correct....
-Ivan
Garcia5
Jul 7, 2022 06:51 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
ANDYZ28
Dec 29, 2014 09:13 PM
blac94Z
Nov 24, 2014 07:12 PM
T-REX
May 14, 2002 08:47 PM
