Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
fuel filter on work van
Old Oct 21, 2008 | 08:16 AM
ryan80z's Avatar
I'm working on a 2003 chevy work truck/van and am trying to remove the filter. The only problem is that between the filter and line is about a quarter inch while all the tools are to big to fit in. I've cut the cheap plastic ones down to fit in but still no luck. I guess my question is, does gm make a tool for filter removal or am I missing something to take it out?
Old Oct 21, 2008 | 12:45 PM
Slick86's Avatar
Its a special fuel clip. Auto parts stores sell them and autozone rents them for deposit cost
Old Oct 21, 2008 | 12:46 PM
Slick86's Avatar
oh and btw, press the line towards the filter, insert the tool down into the line and pull both of them away together.
Old Oct 21, 2008 | 01:46 PM
mccauls_ss_camaro's Avatar
u can remove it without the tool i worked for gm and all we did was push in the tabs on each side and pull it off then to put the new one on push in on hard and then screw on the other side. sometimes we would get a filter with a different clip so we would use the old one. hope this helps
Old Oct 21, 2008 | 05:19 PM
ryan80z's Avatar
It's not the one with 2 visible clips. But I called around n found a shop to take care of it. He said he has a skinnier tool to get it. Doesn't sound right but f it it's not my prob any more. Thanks for the help anyway guys.
Old Oct 21, 2008 | 07:48 PM
ok the one i was talking about was the one with one clip on one side and threaded on ther other inless its a disel.
Old Oct 22, 2008 | 10:25 AM
ryan80z's Avatar
So i took it to the dealership today and had them do it. They had a tool that was longer and flexible.. They did have to take the fuel line off though just to take the filter off. The problem was at one time somebody else installed it, so it's not factory and used the wrong clip. So now I don't feel as bad for not being able to do it in rushed time before having to go out. Thanks again for the replies and help.
PCLZ28
Dec 24, 2015 05:19 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Deadbolt24
Jan 19, 2015 01:29 PM
30thZ4C
Dec 26, 2014 05:09 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
