Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Delteq alternate mounting
Old Sep 19, 2007 | 01:57 PM
David94TA's Avatar
Have any of you mounted the Delteq coils on the radiator shroud? Any problems with water getting on them when driving in the rain? I have mine on my valvecover now, but I put taller valvecovers on to clear my Jesel shaft mount rockers and things are getting a little crowded now. Has anyone tried mounting them on the intake a little further back? Just wondering if that would be subject to more heat and cause problems.
Old Sep 19, 2007 | 08:45 PM
97WS6Pilot's Avatar
I've had mine mounted on the radiator shroud for 2 yrs now with no problems. The coils are sealed anyway even if they did get wet. Its a very clean install and delteq has a bracket for mounting it there. Its a pain when you need to remove the fan shroud because you have to unplug all the wires. Other than that its a good place.
Old Sep 20, 2007 | 02:18 PM
97FormulaWS-6's Avatar
Mine was mounted cross-wise on top of the Intake manifold (back when the car was still in one piece). I've got pictures somewhere. Just took 2 pieces of aluminum, drilled 4 holes in each; 2 for the Fuel-Rail bolts, and 2 for screws into the aluminum plate that came with the Delteq kit.
Old Sep 20, 2007 | 02:39 PM
David94TA's Avatar
OK, Thanks guys.
Old Sep 21, 2007 | 04:04 PM
RE AND CHERYL's Avatar
Mine were under the radiator for 3 1/2 years with no problems. I made no effort to keep them dry and the car was driven in rain with large amounts of water on the street all the time.
Don't worry about it.
Re'
Devinfoote87
Feb 12, 2016 03:21 PM
Thirim
Jul 30, 2015 01:29 PM
Jlo
Jul 29, 2015 03:52 PM
Jul 10, 2015 02:23 PM
Noer
Parts Wanted
Jul 4, 2015 05:13 PM
