Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Connecting stock fuel lines to holley fuel rails?
Old Mar 30, 2011 | 02:26 PM
LT1 POWR's Avatar
Can someone point me in the right direction as to what I need for connecting the stock fuel lines to a holley 9900-172 fuel rail assembly?
Old Mar 30, 2011 | 02:27 PM
LT1 POWR's Avatar
Re: Connecting stock fuel lines to holley fuel rails?
Also, will this fuel pressure regulator be alright for my turbo 383 setup. It looks to be boost referenced.
Old Apr 1, 2011 | 01:53 AM
LT1 POWR's Avatar
Found some pics of this type of setup.
Does this setup look right, with the feed on the rear of the drivers side rail, the return on the rear passenger rail coming out of the regulator and the pressure sender for a gauge on the fitting closest to the regulator?
Whats the stock plastic fuel lines feed and return size? It looks like I'll need something like this and a female-female adapter.
http://www.summitracing.com/parts/AEI-15103/
The feed and return fittings for the fuel rail look like they are both 6an.
Old Apr 1, 2011 | 05:24 AM
MikeGyver's Avatar
feed is just the standard 3/8" and return is 5/16" I believe.
Not using the stock intake?
Old Apr 1, 2011 | 12:15 PM
LT1 POWR's Avatar
Nope, using a holley single plane. Trying to be different than everyone else has aroused a lot of questions.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Jul 4, 2005 05:00 PM
