Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Car no start with MSD box
Old Jul 3, 2011 | 03:50 PM
mrmint69's Avatar
My car had a problem and would not start. I bypassed the MSD box and it fired up and ran fine. Is there some way to check them to see if its still good?
Old Jul 3, 2011 | 05:40 PM
Re: Car no start with MSD box
Are you sure the MSD box has power?
Old Jul 8, 2011 | 01:20 PM
mrmint69's Avatar
I realized I just changed the battery and the MSD box is connected directly to the battery. Might have missed hooking it back up. I will have to check that out. Does anyone know if there are alternate wiring options as far as where it can be hooked up?
Old Jul 18, 2011 | 08:38 AM
MysticBowtie's Avatar
I used the factory junction box that is on the strut tower just behind the battery with an in-line fuse.
Old Jul 23, 2011 | 09:56 AM
dennis5374's Avatar
Is it a streetfire cdi box? I had major issues with mine. Worked fine for a week then started red lighting and had too unhook it for the car too run again.
Old Jul 23, 2011 | 05:59 PM
Kevin Blown 95 TA's Avatar
Not saying this is your problem, but just maybe something to try...
I have a Crane Hi 6 that did that a couple weeks after I installed it. Ran for a while then randomly stalled and wouldn't start. Then later it ran, then didn't again. It turned out that it wasn't compatable with the MSD blaster coil I had, so when I changed to a Crane coil, then it has been running over 10 years without a hiccup. In my case, anyway, it was the impedance of the coil that was borderline for the box to make the box try to protect itself, turn off, and give an error light.
mr28
Apr 20, 2016 05:44 PM
thenewkid
Nov 27, 2014 09:41 AM
USAirman93
Nov 24, 2014 03:37 PM
mr28
Nov 23, 2014 11:11 AM
Dave19yz28
Jan 26, 2003 01:45 PM
