Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
alittle trouble putting fuel pump in
Old Dec 12, 2006 | 02:42 PM
94_camm's Avatar
Ok..Everythings done i just cant get that white strainer on the bottom of the bucket...any tips?94 lt1
Also any good way on getting the gas out of the tank?
Old Dec 14, 2006 | 02:30 PM
mzgp5x's Avatar
I have a 1997, and, there is a red wire near the passenger side PCM area. Connect this to 12+, and the fuel pump will run. Thus, you can empty the tank with the fuel delivery line dumping to a gas can.
Also, I had the same problem with white filter (on Walbro 255lph), so, I did not use it. I cut a hole in my rear pan, so, it's easy to remove the fuel sending unit. Last time I had the unit out of the tank, there was some particulate matter held by the fine mesh screen. I cleaned it off. Both pumps still running fine. 97SS/ 383 - FI/ dual Walbro in tank.
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
blac94Z
Nov 24, 2014 07:12 PM
