Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Which AFPR fits a 93 Fbody?
Old Apr 9, 2011 | 09:47 PM
user 647483's Avatar
I'm having a little trouble identifying an AFPR that will fit my 93 Firehawk.
As I understand it, there are four designs for LT1s and the 93 is specific to that year.
I keep seeing parts listed as 93-97 though.
Problem is, I can't tell which ones really fit both (IE: have left and right mount brackets) and which are just typos.
Yes, I understand how the AFPR works
Yes, I have a specific application requiring more than stock FP
Yes, I plan on tuning for it
Although I have seen several setups (including Lethal's) and they do look awesome,
I don't really want to run an external AFPR with AN fittings, the stock lines are more than enough for what I am doing.
Old Apr 9, 2011 | 10:10 PM
Re: Which AFPR fits a 93 Fbody?
For example.
My stock FPR looks like this; (tab on left)
While a 94-97 AFPR looks like this; (tab on right)
Old Apr 10, 2011 | 05:06 PM
You can buy a kit that replaces the top of your stock FPR.
http://www.fbodymotorsports.com/inc/sdetail/9464
Old Apr 10, 2011 | 05:42 PM
I saw that one; I really don't like the idea of hacking up an FPR, but it is an option.
I also found one from Holley that claims to fit a 93 but they're backordred for a month.
The only other option I see if running AN fittings and a universal regulator.
My build just doesn't really need something that extensive.
Old Apr 10, 2011 | 06:46 PM
I also found ACCEL 74565
Old Apr 22, 2011 | 08:01 AM
Wilson's Avatar
I've been using the Metco one. Its listed here for $62.99. I recall it being pretty easy to convert the stock to a adjustable.
http://www.thunderracing.com/shop-by...re-Regulators/
Old Apr 22, 2011 | 08:07 AM
I ended up buying a Kirban billet AFPR. It worked out perfectly.
That unit is discontinued though so tech support and replacement units will be non-existant.
When I contacted Kirban with questions the response was along the lines of "Yeah, we don't make that anymore; Good luck"
Old Apr 22, 2011 | 08:32 AM
Mr_Bond's Avatar
Just for future reference, any AFPR for a 92-96 LT1 corvette will work for a 93 Camaro. The tab is on the same side.
meissen
Jun 1, 2015 07:59 AM
Drtryder
Apr 22, 2015 04:17 PM
87Aerocoupe
Mar 20, 2015 01:23 AM
CobraEatr
Jul 24, 2004 11:37 AM
Camaro_Eric
Aug 8, 2002 12:21 PM
