95 Camaro Z28 Fuel Tank Pressure
I have a 1995 Camaro Z28. I put a new fuel pump and fuel filter in it and now it builds pressure in the tank, gas boils, and the vent valve pours fuel everywhere, the engine bogs down and dies. I have been told it can be anything from a vacuum line for Evap Solenoid or a plugged/defective charcoal canister. Any suggestions?
Re: 95 Camaro Z28 Fuel Tank Pressure
What pump did you install?
Pressure comes from excessive heat, causing large amounts of fuel to vaporize. May be a problem with a faulty or incorrect pump.
What was the original problem that led you to replace the pump.
Are you sure you connected the vent valve and EVAP canister lines to the correct pipes on the sender assembly?
CamaroHeed
Mar 18, 2020 09:50 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
grendal
Apr 15, 2010 05:20 PM
2000silverz28
Jul 20, 2002 06:14 AM
