95 camaro Turns off when accelerating
My 1995 z28 camaro shuts off when i slam on the gas all the way. What can this be?????????
I changed the fuel pump,fuel filter, spark plug wires, spark plugs, distributor
And there is no check engine light
Re: 95 camaro Turns off when accelerating
Check the rubber inlet elbow, between the MAF sensor and the throttle body, for a large tear, or possibly not being fully over the throttle body flange.
Before and after the fuel pump/filter replacement did you check the fuel pressure with the engine under load?
Are there any major mods to the engine?
