94 z28
94 z28
New here but have been reading a lot of these forums have 94 z28 no spark I no topic is old but after doing test suggested at icm I'm receiving proper voltage at a & d ground and the 1-4 pulse voltage but nothing from coil had icm tested five times to ensure wasn't failing after warming up passed and coil was with tolerance on primary and secondary but no fire from coil any help would be welcomed.
Re: 94 z28
Did you use Shoebox's guide when testing the ICM harness connections?
4th Gen LT1 F-body Tech Articles
Re: 94 z28
I also have the water pump off and intake tube off to have access to Opti will have those off with their sensors unplugged cause no spark? Had no spark before started diagnosis so wasn't sure.
Re: 94 z28
Shoebox’s procedure doesn’t include any tests which produce 60 ohm readings on the Opti harness or the ICM harness. So I'll assume the answer to my question is “no, I didn’t use that procedure.” What procedure did you use - could you provide a reference or a link?
And I really hate to get picky, but without using any punctuation, it’s extremely difficult to understand what you are actually saying. May explain why no one else has jumped in here.
Re: 94 z28
LT1Zcar
Oct 11, 2008 10:43 PM
LT1Zcar
Oct 11, 2008 09:46 PM
