Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
80lb Injectors on 92/93 LT1 - idle issues?
Old Jul 18, 2012 | 01:36 PM
djxib's Avatar
Hi - I am running a YSi supercharger on 92 LT1- mask $DA2. I'd like to change my injectors from 60's to 80's because i'm running out of pulsewidth above 5500 rpm. I'm aware I may have idle issues due to the 80's not being able to deliver a small enough pw and therefore idle will be rich- and this seems especially true on these batch fire ECMs.
So - anyone running 80's in $DA2/3? If so, what's the minimum PW you're seeing and what offsets are you using? How is your idle quality?
Thanks!
Gtpguy
Jan 26, 2015 04:50 PM
Alex Barnes
Jan 24, 2015 10:21 PM
David Dorris
Jan 17, 2015 08:10 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
