80lb Injectors on 92/93 LT1 - idle issues?
Hi - I am running a YSi supercharger on 92 LT1- mask $DA2. I'd like to change my injectors from 60's to 80's because i'm running out of pulsewidth above 5500 rpm. I'm aware I may have idle issues due to the 80's not being able to deliver a small enough pw and therefore idle will be rich- and this seems especially true on these batch fire ECMs.
So - anyone running 80's in $DA2/3? If so, what's the minimum PW you're seeing and what offsets are you using? How is your idle quality? Thanks! |
