Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
30lb injectors?
Old Nov 13, 2010 | 04:56 PM
jdelaprida's Avatar
30lb injectors?
i have a 96' z28 with a cold air, and slp exhaust.
if i put 30lb injectors on would i gain horsepower, or would that just be too much fuel into the engine?
Old Nov 13, 2010 | 10:23 PM
Re: 30lb injectors?
Stock injectors are all you need. When you go past 350 flywheel HP, go larger. Using a larger injector than you need will not gain you any power. The PCM has to be programmed with the new injector size, and will just reduce the injector pulse widths, so it delivers the eact same amount of fuel your stock injectors were providing.
If you install them without a PCM tune, it will run rich, particularly at wide open throttle.
13qtr
Oct 28, 2016 08:11 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
