Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
30-35# injectors
Old Feb 17, 2011 | 01:45 PM
LSWHO's Avatar
30-35# injectors
I'm looking for new injectors in that range. I found a website that sells cheap good injectors that have been flow tested, but can't find it. I'd like to stay as cheap as possible, but not obviously getting trash.
Anybody have any links?
Also, with the injectors I need the tuning table for batt volt. Can anybody send me a link to their prefered injectors and their table?
thanks
Old Feb 17, 2011 | 02:56 PM
henryz28's Avatar
Re: 30-35# injectors
http://fuelinjectorconnection.com/shop/
Old Feb 17, 2011 | 04:19 PM
Gtpguy's Avatar
This is where I was going get some for the GTA
Here is their deal on 30# http://www.southbayfuelinjectors.com...amaro_LT1.html
Old Feb 17, 2011 | 04:38 PM
henryz28's Avatar
I would go with the ev6 type injectors not ev1s
LSWHO's Avatar
Nice, I still need tune info on these though. I need injectors asap and need to tune for them.
Old Feb 17, 2011 | 04:40 PM
henryz28's Avatar
these are much better http://fuelinjectorconnection.com/sh...&productId=178
LSWHO's Avatar
explain please
Old Feb 17, 2011 | 04:45 PM
henryz28's Avatar
those ev1s spray from a single hole and give more of a squirt; the ev6 style spray from 4-6 holes and give a nice spray. the ev1s have a higher chance of clogging also
Old Feb 17, 2011 | 04:50 PM
henryz28's Avatar
You can give fuelinjectorconnection.com a call at 770 888 1662 and they will be able to answer your questions on their injectors.
Old Feb 17, 2011 | 07:33 PM
Gtpguy's Avatar
The dude on Fuelinjectorconnection just trolls boards. He's really annoying and won't do business with him just because of they way he conducts himself on TGO. He will argue with other vendors, its just immature for a business to do that.
Southbay is cheaper, and the guy isn't a troll. Take if for what it's worth.
EV1 is more of a sprinkler or shower head spray, not a squirt.
Old Feb 17, 2011 | 09:13 PM
henryz28's Avatar
Either way the ev6 is the superior injector and well worth the extra $20. The ev6 has improve atomization of the fuel; better burn, and it has quicker action (the pintle has less mass, and the coil saturates and de-saturates more quickly/cleanly) bottom line ev6 are superior. I had a set of ev1s and ev6 style injectors put on the flow machine and you can clearly see the superior spray pattern of the ev6 injectors.
Old Feb 17, 2011 | 09:30 PM
Gtpguy's Avatar
Bottom line is the only ones that will experience any sort of mph or hp gain going to new injectors is by those people with 20 year old rusty, corroded injectors with blown out coils. Not the people swapping from EV1 to EV6. Meaning the difference between the 2 is so insignificant, its just whose sales pitch you liked better.
Thats the bottom line 'cuz Stone Cold said so.
Old Feb 17, 2011 | 09:48 PM
henryz28's Avatar
Not 100% correct modded cars will see a hp gain if the old stock injectors are not putting out enough fuel. Its not all about hp gain, the ev6 injectors will produce a better cleaner burn, as a result the car will Idle and run smoother. There is a reason why ford has stopped producing the ev1 style and switched to the ev6 style with ev1 connectors.
Old Feb 18, 2011 | 05:28 AM
shawngamblez28's Avatar
Lightbulb Re: 30-35# injectors
for what it is worth i bought a brand new set of venom 30lb injectors for 187.00 shipped to my door from amazon.com plugged rite n. just let n u know
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
