Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
1998 z28 Stalls and revs up trying to get gas it seems then stalls out
Old May 12, 2017 | 01:04 PM
Jamil Stewart's Avatar
When it's not in no gear just sitting does same thing changed the fuel filter what should be my next step
Old May 12, 2017 | 05:00 PM
Re: 1998 z28 Stalls and revs up trying to get gas it seems then stalls out
I've did that the next thing I was the change the throttle sensor
Old May 12, 2017 | 05:34 PM
JakeRobb's Avatar
Super Moderator
Is the service engine light on? Have you checked it for codes?
Bad MAF, bad IAC, or any number of other sensors could do that. So could a vacuum leak.
Stop wasting your money by throwing parts at it and do a proper diagnosis.
Old May 12, 2017 | 05:39 PM
yes check engine light is on but it's for a o2 sensor
Old May 12, 2017 | 08:20 PM
What is the exact code? P????
Old May 20, 2017 | 04:54 PM
JakeRobb's Avatar
Super Moderator
An O2 sensor could could definitely explain these symptoms. The exact code(s) will help.
