Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
1998 camaro z28 fuel problems
Old Oct 4, 2010 | 10:43 AM
98LS1camaro's Avatar
My 1998 camaro ls1 running is running like ****. It only hold 20 -30psi of pressure. the guy i bought it from said he changed the whole fuel pump assembly. it all looks new. i changed the regulator when i bought the car and it ran fine. all of a sudden it started running like this. i can sit in the car and listen to the fuel pump whine. it gets loud and then quite like it working ti hard. im confused on what the hell to do. i was just thinking of just replacing the whole assembly. i found a 1999 assembly complete from racetonix for 100. but it only has 3 lines instead of the 4 lines that my car has.
Old Mar 2, 2011 | 08:36 AM
hockey_goali's Avatar
Re: 1998 camaro z28 fuel problems
the same thing is happening to mine, i changed my oil and it seemed to get worse. it shakes when im idling and when im at a red light and stuff. and the oil gauge is always flipping out or its on 0, and i just refilled it. im getting it checked out today. ill let you know whats wrong with it so you can check yours out
Old Mar 2, 2011 | 07:08 PM
Under what conditions are you seeing "20 -30psi of pressure"? Have you checked the fuel filter? Have you checked the fuel pressure regulator? Have you checked the hose connections in the tank to make sure they are not leaking?
hotrodyou1
Dec 20, 2014 10:05 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
siguy
Nov 27, 2014 10:07 AM
grendal
Apr 15, 2010 05:20 PM
2000silverz28
Jul 20, 2002 06:14 AM
