Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
1983 Z-28 crossfire injection
Old Aug 1, 2010 | 12:07 AM
DEDHHH's Avatar
I have a 1983 with crossfire injection. i bought it without a motor but i have the intake manifold and throttle body and injectors. What other sensors and parts do i need to make it work with another 305c.i. or 350c.i. motor? any help would be appreciated, Thanks, DED.
Old Aug 1, 2010 | 09:23 AM
You need to get a wiring diagram for the ECM/engine, and duplicate everything in the diagram. I have a diagram in my Chiltons manual, and another in a Corvette Fuel Injection manual, that should be similar, if not identical. Chilton's is not always 100% accurate. Between the two diagrams you may be able to work it out correctly.
I can scan them and send you copies if you want.
You are aware that the L83 is also known as "Ceasefire" Injection.....
IndyZman
Oct 22, 2015 02:17 PM
drt
Sep 27, 2015 04:39 PM
rvonsternberg
Sep 14, 2015 11:58 AM
heus
Sep 8, 2015 12:01 PM
Henson071
Aug 4, 2015 09:32 AM
