Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
1968 302 timing
Old Jul 11, 2011 | 10:28 PM
first_one's Avatar
1968 302 timing
Hi all,
I have a 1968 302. I'm looking for some help for proper timing setting.
The engine has 11:1 pistons, 30-30 cam, 800 holley, winters hi-rise, camelback heads. I have a slight problems with it sputering after engine shutdown. The timing was at 14, and was turned back to 8, this didnt help. I thought I'd throw it out to you guys for some advice before I start adjusting too much. Thx
Old Jul 12, 2011 | 12:12 PM
Kevin Blown 95 TA's Avatar
Re: 1968 302 timing
It is more a problem of having the throttle blades slightly open when you turn off the ignition. One fix is an idle solenoid like they used to use on cars with AC to bump the idle when the AC was turned on so the car wouldn't stall. Only you would use it to close the blades when the ignition is turned off. The Holley solenoid is like $70 though, and that's a ripoff. If you look up the parts and understand the concept of what I'm talking about, maybe you can adapt one on there for less money than that. My buddy built an old Nova which has the same problem - not sure what he's going to do about it yet.
Feffman
Oct 9, 2015 05:42 AM
bose
Jan 30, 2015 02:36 PM
NewsBot
Jan 21, 2015 06:10 PM
Carson96Z28
Aug 28, 2002 05:23 PM
guionM
18
Jul 11, 2002 01:45 AM
