xe 224/236 s/c cam on a 114lsa
Old Jan 16, 2003 | 04:25 PM
  #16
FireAm94's Avatar
If people are passing with the cc306 I would imaging there would be no problems with this cam.
Joe
Old Jan 16, 2003 | 09:47 PM
  #17
Maldo's Avatar
cool just wanted to see if ti was possible
Old Jan 18, 2003 | 09:12 AM
  #18
Maldo's Avatar
oh by the way what is the part number for this cam ... i tryed to orderit from summit and they do not have a listing for it
Thanks,
Jim
Old Jan 18, 2003 | 10:00 AM
  #19
rskrause's Avatar
Moderator
It's a "custom" cam. To order you need to specify the type/year of car, intake and exhaust lobe pn, lsa, and intake center line. Expect to pay close to full list (which is a bit more than an "off-the-shelf" price) for a "custom cam.
lobe #3314 224@0.050" .335" lobe lift
lobe #3192 224@0.050" .378" lobe lift
lobe #3316 236@0.050" .347" lobe lift
lobe #3196 236@0.050" .390" lobe lift
So, you can order a ligh or low lift version using either 3314//3196 or 3192/3196 depending on how high you want to rev it, what springs you plan to use, etc. If you send email to me at my friend Bob's shop I can get a quote for you. Send to my attention at rjk@buffnet.net.
Rich Krause
Old Jan 18, 2003 | 10:21 AM
  #20
Maldo's Avatar
Hi,
This is the specs from thunder racing:
63-224/236-114 Comp Cams "Extreme" LT1 Camshaft, 224 / 236, .502 / .520 114 LSA, Very aggressive camshaft for street/strip blower applications. Heads, Exhaust, Stall or M6, Computer tuning required
$249.99
what version is this one ?
I just pulled my motor last night to replace a broken piston ... so i figured while i was in there i might as well put a bigger cam and this some seems to fit what i am useing. (also i am running lt4 hot cam springs)
can your freinds place do better then that price and have it to me by next week? (in NJ)
Send me an emal if you do not wish to post price etc.
I am trying to get the motor up and running by next week .
Tanks,
Jim
Old Jan 20, 2003 | 07:42 AM
  #21
rskrause's Avatar
Moderator
Originally posted by Maldo
Hi,
$249.99
Tanks,
Jim
Sorry, but it would be more expensive from my buddy as it's a "custom" order and would also take 10-14days. The cam Thunder Racing has specced out is the low lift version. I think it will work fine, but I'd rather see a 116lsa. The high v. low lift is more complicated, but suffice it to say I am using the high lift version.
Good luck.
Rich Krause
Old Jan 20, 2003 | 01:51 PM
  #22
MEAN LT1's Avatar
Im using the one from thunder racing. So im using the low lift version does that mean im not goona make as much power up high?. It says it'll make power all the way up too 6800rpm.
Old Jan 20, 2003 | 03:59 PM
  #23
Maldo's Avatar
Where can i get this cam ...... nobody stocks them i am looking to get this by this weekend
Old Jan 20, 2003 | 09:47 PM
  #24
Maldo's Avatar
Funny thing is that I tried to buy this cam today and I was told 7-14 days
is there any off the self cams similar to this one I can buy.
Old Jan 20, 2003 | 11:31 PM
  #25
94irocz's Avatar
I've called looking for this cam before. I got mine on a custom cam gp that thunderracing did. But I also called nu-tek and they stock this same cam. I believe it is the low lift version. Give them a call and see if they have one in stock if ya don't want to wait, they might have one in stock. They did when I called them.
Joe
Old Jan 21, 2003 | 07:17 AM
  #26
MEAN LT1's Avatar
Thunderracing, racenet.net,nu-tek, all these companys have this cam on shelf.
Old Jan 21, 2003 | 12:38 PM
  #27
Maldo's Avatar
yeeeeeee haaaaa i got one (from thunder racing) I should have it by thrus....
How do you guys think my lt4 hot cam springs hold up agaisnt this cam? (should I change the springs?)
Also does anyone have sound clips for this cam?
Thanks,
Jim
Old Jan 21, 2003 | 02:17 PM
  #28
Maldo's Avatar
Dammmmmmmmmmm i just got a call back from thunder racing telling me that they could not complete my order (the guy did not check stock before he took my order)
This is beginning to look like a nightmare to get this cam... Funny I thought that this was a popular cam so I figured that someone would stock the dammmm thing. Oh well I guess I am stuck with my other blower cam for know.....
Does anyone know of anther cam that is similar?
Old Jan 21, 2003 | 02:38 PM
  #29
FireAm94's Avatar
Hmm....maybe it's fate telling you that a cam install shouldn't be rushed???
Old Jan 21, 2003 | 04:18 PM
  #30
94irocz's Avatar
Did you try nu-tek?
