Wiseco or Diamond Blower Pistons?
I was looking at the Wiseco pistons (part#K431A4 -15cc dish) and the Diamond pistons(Part#11422 -22cc dish) so I would like a little input on what piston everyone would recommend.
These will be going in a Procharged LT1 running 15-18 psi from a D1. With my heads the wiseco's will give about 8.8:1 compression ratio. The motor was previously built but do to crappy machine work/engine assembly I'm going to have to go .040 on the bore. I already have Forged H-beams and will be running a forged 3.48 stroke crank.
I know the diamond's are made of 2618 material but I'm not sure about the Wiseco's. Also I'm not sure how important piston weight is in a blown app but the wiseco's are 433g and the diamond's are 544g. The wiseco's can be bought for $496 and the Diamonds are $616. For the price and the weight I like the Wiseco's but would like some opinions.
Thanks for any help.
Travis
Travis
Re: Wiseco or Diamond Blower Pistons?
I am going to use the Wiseco piston myself and they are 2618. I have no opinion about the Diamond as I have never used any before and just don't know any engine builders that do that I'm in contact with. Its just never came up.
what kinda power are you lookin to put through my old y pipe? haha i went with the -22cc SRP pistons in mine... not as strong as the diamonds, but supposedly strong enough, from what ive read, somethin else is gonna let go before a piston unless you go real lean
I expect to have to dress any budget piston I would use. And luckily aluminum doesn't glow. SRP's are the same way. I would use the FMP LW "turbo" piston if it was a different material. Their material is very close to 4032 though.
Originally Posted by rskrause
I was distinctly unimpressed witht he last set of Wiseco's I saw. They had sharp edges all along the dish relief that had to be smoothed over.
Rich
Rich
<rich> JE is teh best!!! <rich>
Travis
Travis
Have you considered CP pistons? I've had great luck with them although they are pricey..... I've also heard of folks having great success with the Diamond brand as well.
-Tim
Hey Travis, Who did your machine work? Was it George over in Cannonsburg? At GCP or some place else. HAte to hear you have to rebuild. I wish I spent a bit more on my I-beams. I hope to get my car going in the next month or so.
Byles machine shop.....Its located behind NAPA on Greenup Ave . I'm going to have my buddy at Performance do the machince work this time.
Good luck with your car
