will i need a intercooler with 6lbs of boost?
Old Sep 17, 2003 | 12:03 AM
93formula's Avatar
is a inter/aftercooler neccasary if i run 6lbs of boost? will i feel teh difference or is it a waste of money for my purpose? thanks
Old Sep 17, 2003 | 10:35 AM
radik's Avatar
Most kits are setup for 6# non intercooled you would be fine.. although i would pick one up anyway because boost is like crack.
Old Sep 17, 2003 | 01:36 PM
ATMINF's Avatar
I would say yes. That is because I saw what happened to earlier 5 psi systems from Vortech that were not inter/aftercooled out in the hot southern California summers. One word-"BOOM".
Old Sep 17, 2003 | 02:59 PM
PatrickCarter's Avatar
Big difference between BC and cali
P
Old Sep 17, 2003 | 08:00 PM
93formula's Avatar
so in BC ill be fine with 6lbs of boost? and aggie i was the one who e miled you about your intercooler so you still wanna talk me outta one? its a daily driver and i really dont want more boost then that. im planning on runnig nitrous with it at the track. so if i was to go with higher boost then i should get one but for now im alright correct?
Old Sep 17, 2003 | 10:26 PM
ATMINF's Avatar
I would still say no. But what do I know, only that my sc setup last over 95,000 miles and the reason why it went bad was due to the FMU going bad.
Old Sep 18, 2003 | 12:19 AM
BPS's Avatar
BPS
no intercooler required here for 6# - but of you plan on going higher then look into getting one
Old Sep 18, 2003 | 01:03 AM
SloLt1Z's Avatar
You really wouldn't need it, but it's a good idea. Like the blower in general, you don't NEED it but it's a good idea.
Old Sep 18, 2003 | 10:01 AM
94LT1_89TTA's Avatar
I'm going on (3) years now without one. No problems yet. I do use conservative timing (27 degrees) though.
Old Sep 18, 2003 | 12:55 PM
Rival's Avatar
it would be safer. less detontion.
Old Sep 18, 2003 | 06:46 PM
RCF925's Avatar
I would get one, The cooler your intake temps the more HP
Old Sep 18, 2003 | 07:33 PM
BOOST FED 95Z's Avatar
I would get one. I had one and sold it and now wish I had it back. I am running around 16-18 psi w/ no cooler. I will be purchasing another when I find the right deal.
Scott
Old Sep 18, 2003 | 07:35 PM
93formula's Avatar
hmmm, well if i come across the right deal then i shall pick one up as well, thanks guys!
RUENUF
Mar 13, 2016 03:37 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
96SilverRam
Sep 7, 2015 10:51 PM
Henson071
Aug 4, 2015 09:32 AM
