Will I lose boost?
Old Jan 29, 2003 | 10:58 PM
GEES97TA's Avatar
Will I lose boost?
Just wondering how much boost i will be losing after they install the Ported/polished heads on, and the MAC headers. I had a 4.5 psi kit before with stock heads and manifolds now i have the 6 psi kit and soild intake tube and larger air filter so will i lose boost and make better hp or will i see the same boost on the gauge or lose boost and gain somewhere else
Old Jan 29, 2003 | 11:01 PM
BigDaddy's Avatar
You may lose pressure due to less restriction, but not volume.
Old Jan 30, 2003 | 01:12 AM
TimbrSS's Avatar
Boost is just a measurement of air backed up in the intake. With P&P heads, you'll SC will be flowing the same amount of air, you'll just be getting more of it into the cylinder... Lower boost reading, more power!
Old Jan 30, 2003 | 07:14 AM
Willie's Avatar
Timbr said it well. The key point is that boost is "resistance to flow". The less resistance, the more flow!!
Old Jan 30, 2003 | 10:20 PM
GEES97TA's Avatar
Ok so does that mean i will lose boost at a faster rate and make more power, or make more power and not see it on the gauge?
Old Jan 30, 2003 | 11:09 PM
TimbrSS's Avatar
You will make more power and not see as much boost as you previously saw on the gauge, assuming you don't change pullies on the SC.
I don't know what you mean by lose boost at a faster rate? when you lift your foot of the pedal, all the boost is gone.
Old Jan 30, 2003 | 11:15 PM
FireAm94's Avatar
All the guage measures is intake manifold boost.
Old Jan 30, 2003 | 11:16 PM
GEES97TA's Avatar
I meant that when adding P/P heads and larger valves will i lose boost on the gauge at a faster rate meaning will it respond better before it kinda felt like it had a lag to it almost like a turbo. But could that have been the the false knock i was getting it was about 9 degrees from begin to end on the dyno.... Plus i was using the 4.5 psi kit then and now i have the 6 psi kit and soild intke tube and a 9 inch k@n element too..
RUENUF
Mar 13, 2016 03:37 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
96SilverRam
Sep 7, 2015 10:51 PM
Henson071
Aug 4, 2015 09:32 AM
