Will a BOV Lower my IAT's at idle?
Old Sep 10, 2005 | 05:20 PM
97WS6Pilot's Avatar
I scanned my IAT's after a long idle with the AC on in my garage with no airflow to the intercooler. The highest it reached was 183F. Will switching to a blowoff valve and a blow thru MAF solve this problem on my procharger?
Old Sep 10, 2005 | 07:15 PM
Alvin@pcmforless.com's Avatar
Re: Will a BOV Lower my IAT's at idle?
Is your intercooler sitting on your radiator?
I would say no, it won't affect temps at a idle.
Old Sep 10, 2005 | 07:53 PM
PWRMAD95's Avatar
Definitally, if you're recirculating the air right now.
I'm using a 2" ,dumped to atmosphere, bov in place of the bypass and a very large intercooler.
My idle air temps are the same as ambient temp outside.
Using the bov instead of the bypass required a little shortening of the spring inside the bov. The stock spring was preloading the diaphgram too much to allow it to dump at idle.
Old Sep 10, 2005 | 09:48 PM
97WS6Pilot's Avatar
Its mounted horizontally under the Swaybar with a bottom scoop. The radiator fans blow hot air on it at idle and below 35 mph. Its similar to the 2 core but bigger. Its a custom job. No room for a intercooler fan down there.
It would seem that if I vented to atmosphere it would cool the IAT's by flowing all that air through the intake track. The best way would be to have an FMIC but I'm not wanting to cut up my car.
Old Sep 10, 2005 | 09:53 PM
97WS6Pilot's Avatar
Where is your intercooler mounted? Is it cooled by a fan? There must be something wrong with your IAT probe. I didn't even get ambient IAT's with the stock ram air and no blower. Much less with a supercharger.
Old Sep 10, 2005 | 10:08 PM
I didn't hink oabout it that way.. It probally would coool things off a bit.
Old Sep 11, 2005 | 12:46 AM
PWRMAD95's Avatar
There is nothing wrong with the iat probe .
The bov dumps the air before the intercooler to keep the ic from becoming heatsoaked.
As for the intercooler mounting, in this pic you can see about half of the intercooler. It's as wide as the turn signals and tucks in behind the headlight assemblies at the top.
Old Sep 11, 2005 | 10:40 AM
97WS6Pilot's Avatar
That is a huge intercooler. Nice looking too. Thanks for the idea. I didn't think of venting to atmosphere before the intercooler. Everybody elses I've seen dumps close to the MAF and Throttle body. I think your setup might solve my IAT problem at idle.
Old Sep 12, 2005 | 09:31 AM
flusz28's Avatar
kinda off subject, but i don't have a innercooler or have ac anymore. but a cheap BOV to buy is from the 1g turbo cars-eclipse,talon,etc.. thats what i use and it sounds cool and works well. www.dsmtrader.com
Noenav
Mar 1, 2019 07:38 AM
Nickster 7
May 1, 2015 09:04 PM
87Aerocoupe
Apr 12, 2015 12:25 AM
grabbem88
Feb 13, 2015 03:09 PM
HectorM52
Jan 31, 2015 07:29 PM
