Will 987 springs handle this cam?
Re: Will 987 springs handle this cam?
Originally Posted by 96vortechSS
TS-239XR 239/248 duration, .577"/.600", 115lsa?
Well, either way, you'll be at the very outer limits of the 987's as I believe the max lift on their specs is .600".
I thought that was a Crane Cams part number? I can't find it on their website. I'm running the 10308 set, and it has the 893's in it.....at least according to their site....
The best source for spring info is the cam grinder. Answering your question would be easier, and hence more likely to get responses, if you posted more details of the setup and what the springs specs are, rather than just a pn.
Rich
Rich
Bryan: they are a comp spring.
The specs on the springs are: 1.430 2 spring, .697 I.D., seat load 121@1.800, open load 388@ 1.200, 1.150 coil bind, rate lbs./in. 344
Originally Posted by Schurters LT1
You should look for something in the 130+ range on the set or what ever the person selling you the cam says.
yes,
You need a little more spring when your are FI..Get the matching spring for the cam, where ever you buy a cam,
I'm probably going to get a .560/.577 lift cam and these are the springs they recommend @ combination motorsports.
Why do they need to be 130+ lbs on the seat in a FI car?
Rich
Oh, thanks rich I've been looking at comps website for a long time now and I can't find a spring that has both the seat and open pressures I'm looking for. I'm looking for a spring with at least 130lbs seat pressure and 350lbs open pressure. This is pretty difficult.
The 977part number specs out to 155lbs seat press. @ 1.850, 419lbs open pressure @ 1.250, a coil bind 1.195. This spring will support up to a .595 lift cam. The outside diameter is a little larger than the 987 so I don't know if it'll fit in the head seat with out some machineing.
Comp said that the lifters couldn't really take the 419 open pressure. I've come to not put a lot of faith in their word over the phone. Do you think I'd have lifter promlems with using these springs?
