Who is running F1 Prochargers on LT1's ?
Old Aug 2, 2007 | 05:48 PM
  #16
CALL911's Avatar
Originally Posted by Fastbird93
As ZBLKHELLRZR mentioned, I'll be running an F1A on my new setup, pullied to put out as much as it will at about 6500-6700 RPM (read max impeller speed). Nothing cosmic, just a good bottom end and a ported TFS headed top end. Still have a LONG way to go though.
Light a fire underneath it! Get that thing going!!
(I'm impatient )
Old Aug 2, 2007 | 05:57 PM
  #17
Fastbird93's Avatar
(I'm impatient )
I'm trying. I'll have the old motor out and torn down on Saturday (provided the hangover isn't too bad) and once I get that parted out I'll concentrate on ordering the extras for the new motor.
I think I'm going to ditch the intercoolers and run straight Meth though. There's just no room for a good and efficient FMIC on the LT1 T/A's, the ATI twins while good, will probably cost me a bit in the boost drop area and clutter up all the pipes, so I figure why not just go straight to the intake and use meth all the time.
Old Aug 2, 2007 | 06:08 PM
  #18
CALL911's Avatar
(sorry in advance to hijack the thread)
Keep in mind that you might be limiting yourself to only so much HP by skipping out on the intercoolers. The methanol will help, but even if you are spraying like a madman it will only help cool so much. You will have gobs of boost and power from the F1 (especially from not running an IC if thats what you choose). But while tuning it, you might be able to only run so much timing if things are getting too hot even with the methanol. I would say, stick with the twins to help things out, and then you can max out the power as I know you want to.
Old Aug 2, 2007 | 07:22 PM
  #19
Fastbird93's Avatar
Man, listen to you! I know fully well that I may be limiting myself by not running intercoolers, but again, the twins are going to be a PITA to install, clog up the front end with piping, and aren't going to be terribly efficient. If I could use the LS1 4.5" twins I'd probably stick with them but the 3.5's aren't going to be up to the F1A task.
I am considering a horizontally mounted FMIC and cutting back the nose some on the underside, but even that is going to only be so efficient considering the airflow potential over it. I figure since the T/A front end doesn't allow for a very efficient intercooler why fight it, and shoot the injection, no intercooler, keep things simple, and don't fight it. It's going to make what it makes. I haven't decided if I'm going to go for this or no intercoolers, but right now I just don't feel like fighting the Twins.
Old Aug 2, 2007 | 08:25 PM
  #20
tubby's Avatar
i've been running the F1 for years in my t/a
Old Aug 2, 2007 | 08:31 PM
  #21
CALL911's Avatar
Ehh.... fight the twins. By themselfves you are right they won't help out much, but with the meth they may be all the difference you need to max out the power. If you wanted an easy car to work on, you should know by now an LT1 is never easy
Old Aug 3, 2007 | 12:41 AM
  #22
ramair96ws6's Avatar
Im running air/water on my car and it works great i can send you some pics if you would want
Old Aug 3, 2007 | 01:41 AM
  #23
Fastbird93's Avatar
Too much entailed for an Air/Water intercooler. Thanks though.
Old Aug 3, 2007 | 02:39 PM
  #24
Ponyhntr's Avatar
I'm running an F1x non-intercooled.
Old Aug 3, 2007 | 03:11 PM
  #25
92LT1RS's Avatar
F1x?
Old Aug 3, 2007 | 03:13 PM
  #26
Ponyhntr's Avatar
Originally Posted by 92LT1RS
F1x?
It's an F1 ABCD... in other words I'm not saying as of yet! :P
Old Aug 3, 2007 | 03:33 PM
  #27
92LT1RS's Avatar
ok that works
Old Aug 3, 2007 | 03:42 PM
  #28
fabgmc4me's Avatar
I guess while the topic of intercoolers came up in this post.
What is everybody using, and please post some pics if possible.
That will will be one of the few remaining things I have to do.
Old Aug 3, 2007 | 04:01 PM
  #29
ZBLKHELLRZR's Avatar
32X12X4 IC is what I have.
Old Aug 3, 2007 | 05:06 PM
  #30
Fastbird93's Avatar
How's that working out for you? Street car at all? dual nozzle injection I presume?
