who makes the best sc for lt1's?
Old Sep 1, 2003 | 09:28 PM
lldreams's Avatar
Question who makes the best sc for lt1's?
i wanna go fi with my 95z and was wondering on who everyone thinks makes the best sc's for lt1's?
Old Sep 2, 2003 | 12:22 AM
BOOST FED 95Z's Avatar
Vortech IMHO, Do a search, this topic is discussed many many times.
Scott
Old Sep 2, 2003 | 11:30 AM
FireAm94's Avatar
Get vortech if you wanna spend 3k for non-intercooled plus 1k for aftercooler. They are both about the same quality but the ati setup is 1k cheaper.
Joe
Old Sep 2, 2003 | 03:30 PM
ATMINF's Avatar
ATI Procharger is the best in my book, but Vortech makes a good product.
Old Sep 2, 2003 | 06:33 PM
Roadie's Avatar
what about the old paxton superchargers (SN-93)? I've recently seen a few used kits surface... I've seen quite a few negative comments on them, but nothing specific as to failures, etc.
Is anyone on this board using one?
Old Sep 2, 2003 | 10:52 PM
ATMINF's Avatar
The paxton setups were prone to quality control issues. I have seen some work great while others have had some major issues with seals and bearing failers. I also believe paxton was brought out by Vortech a couple of months ago.
Old Sep 3, 2003 | 06:22 AM
IDOXLR8's Avatar
I have owned an ATI p600B, D1SC and now and F1. IMO if you are going to buy a smaller blower than I would go with a S-trim. My reasoning behind that is that every P1SC that I have seen leaks blower oil through the seals. ATI does not warranty it and it will cost you money out of your pocket to fix it. For larger blower I like ATI There is alot less modifications required to install an ATI F1 over a Vortech YS trim.
Old Sep 4, 2003 | 06:07 PM
engineermike's Avatar
I like Vortech because of their impeller design and rock-solid reliability. Also, the "smaller blower" S-trim can supply enough air to run high 9's with off-the-shelf serpentine pulleys:
http://para.noid.org/~lj/
Mike
Old Sep 4, 2003 | 07:26 PM
dynomight's Avatar
Vortech, only cuz i am running one.
Old Sep 4, 2003 | 08:53 PM
RCF925's Avatar
Vortech with Aftercooler is what I'm running and if I had to do it over again I would stick with the Vortech.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
InfernalVortex
Jan 17, 2015 09:35 AM
siguy
Nov 27, 2014 10:07 AM
