who makes the best sc for lt1's?
what about the old paxton superchargers (SN-93)? I've recently seen a few used kits surface... I've seen quite a few negative comments on them, but nothing specific as to failures, etc.
Is anyone on this board using one?
The paxton setups were prone to quality control issues. I have seen some work great while others have had some major issues with seals and bearing failers. I also believe paxton was brought out by Vortech a couple of months ago.
I have owned an ATI p600B, D1SC and now and F1. IMO if you are going to buy a smaller blower than I would go with a S-trim. My reasoning behind that is that every P1SC that I have seen leaks blower oil through the seals. ATI does not warranty it and it will cost you money out of your pocket to fix it. For larger blower I like ATI
There is alot less modifications required to install an ATI F1 over a Vortech YS trim.
I like Vortech because of their impeller design and rock-solid reliability. Also, the "smaller blower" S-trim can supply enough air to run high 9's with off-the-shelf serpentine pulleys:
http://para.noid.org/~lj/
Mike
Mike
F'n1996Z28SS
Aug 23, 2023 11:19 PM
