where to mount GN intercooler?
Old Sep 19, 2003 | 10:28 PM
93formula's Avatar
looks like ill be going with a GN intercooler for cost reasons, right now im just gathering information. but just wondering where would be a good spot for it? the measurements are:
19 inches at the widest point across the face of the core. 10 inches in vertical height across the core. the height does not include the height of the inlet and outlet piping which is approximately 6 inches greater than the core height. The intercoller is just under 4 inches in thickness
ill be getting bigger inlets welded on as it seems the stock ones are restrictive. just wondering where would be a good spot for it? front mount? im worried about overheating issues, ill also be keeping the AC condensor. has anyone done this? any information would be helpful. the blower is a s trim, i was told that the GN intercooler should be fine up to 12 psi, personally i dont want to go over 10 psi, most likely ill be running 6 psi. thanks for you help
Old Sep 22, 2003 | 02:34 AM
93formula's Avatar
no one knows?
Old Sep 24, 2003 | 01:16 AM
93formula's Avatar
i guess ill be the first to do so then
Old Sep 24, 2003 | 01:40 AM
sleepybu's Avatar
get 2 and have them welded togeather, i'd one would be abit restritive
Old Sep 24, 2003 | 01:45 AM
93formula's Avatar
well the turbo buick guys run up to 28 psi on them, the inlets are the part that get restrictive so ill be swappign those out and the most boost id ever want is 8-10. the gn intercooler has about 2-3 psi drop so i should see 6-7 psi of boost. hopefully anyways.
Old Sep 24, 2003 | 01:55 AM
sleepybu's Avatar
a wize guy ehhh ........................
your running less boost but moveing more air
I say go for it and if it 's a cork, do what i said in last post
Old Sep 24, 2003 | 02:04 AM
93formula's Avatar
well after its all done ill let everyone know how it works. since no ones done it here. but its very cost effective, got the intercooler with air scoop for 80 bucks!
Old Sep 24, 2003 | 02:09 AM
sleepybu's Avatar
$80 ............
Old Sep 26, 2003 | 11:43 AM
fast90's Avatar
by a ford durmax intercooler. It has 3 inch intake and exhasut and is about 20 times lasger them the gn intercooler. THis is aboout 150 on ebay. Its a really good cheap upgrade.
Just put it in front of you radiator thats what my freind did on this 3rd gen.
He went from 11' to high 10s just with the Large intercooler.
Shane
Old Sep 26, 2003 | 11:45 AM
fast90's Avatar
Just put it in front of you radiator thats what my friend did on this 3rd gen.
Shane
Old Sep 26, 2003 | 11:47 AM
fast90's Avatar
by a ford durmax intercooler. It has 3 inch intake and exhasut and is about 20 times lager them the gn intercooler. This is aboout 150 on ebay. Its a really good cheap upgrade.
Shane
Old Sep 26, 2003 | 08:19 PM
93formula's Avatar
hmmm, does he still have the ac condensor though? i want to keep mine and need to clear it, ill look into it, but it may be overkill for my application, what boost is he running? i dont ever plan on goig higher then 9 or 10 psi and im gonna start off at 6, and if im happy with 6 psi ill stick with it. what year duramax intercooler? the newer ones?
Old Sep 27, 2003 | 05:15 AM
sleepybu's Avatar
Originally posted by fast90
by a ford durmax intercooler. Shane
durmax is CHEVY
you mean flower choker ...power stroke
Old Sep 27, 2003 | 04:01 PM
96speed's Avatar
The Ford Cummins is an excellent choice .
Do you have a pic of the Grand National IC? Isn't it bottom fed (air) and mounted on the front pass side of the engine on the Grand Nat'ls?
If you can't post it would you please email it to me? rtr350@yahoo.com
Ryan
Old Sep 27, 2003 | 04:12 PM
96speed's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
Nevermind :-).
Ryan
