Whats the max boost one should run with the vortech race bypass valve?
Old Jun 13, 2005 | 03:57 PM
96vortechSS's Avatar
I've read all of the related bypass valve posts and haven't found an answer to my question. I already own a race bypass valve but haven't installed it yet. I don't know how much boost the engine will actually see b/c I've changed my setup somewhat. I'm guessing I'll be seeing somewhere around 13-14psi with the s-trim. My setup is 7" crank pulley, 3.00" blower pulley, 218/230 XE cam, ported heads stock valves, 355 cid, 58mm tb (plennum holes are still 52mm though), and I'm fabing my own hard intake pipe since I can't seem to get a brad brand intake pipe.
Thanks for any advice in advance
Old Jun 14, 2005 | 05:12 PM
breakmyfootoff's Avatar
Re: Whats the max boost one should run with the vortech race bypass valve?
TTT, I want to know too. They have a CFM rating, but how do you judge when to step up to the Mondo?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
MadMav
Feb 6, 2015 11:02 PM
