What Timing controler should I use? Help!!!!
Old Sep 28, 2004 | 10:02 AM
CamaroSS30th's Avatar
Hey guys,
I have a 97 SS w/ built 350 8:1 compression and 12# of boost. I have a MSD 6al with the Boost timing master ad-on box... When I run the motor up it misses at about 5300rpm.. I was told the MSD 6al output was causing the Opti to miss a rotation of the motor... The Opti and motor are Brand new.. less then 50 miles on them... What timing retard box can I use that doesn't amp the signal like the MSD 6al or 6btm? Anyone have a problem like this? Thanks for the help!
-Jay
Old Sep 28, 2004 | 11:10 AM
agrsiv95's Avatar
Re: What Timing controler should I use? Help!!!!
What plugs/gap are you running? Are you sure it's not fuel related. I have a 6AL and works fine to 6200.
J
Old Sep 28, 2004 | 12:14 PM
I'm running NGK TR60 gapped at .35... Fuel seems fine it misses at 5300rpms and is fine at about 5400... on the Dyno graph there is a gap between 5100 or 5200 and 5400rpms. It looses the Ignition signal.
Thanks,
Jay
Old Sep 28, 2004 | 12:17 PM
also... The Dyno graph looks really rough when I have the MSD hooked up (ie. /\/\/\/\/\/\)... then when I unplug the MSD the graph smooths out (ie.__________).
Thanks,
Jay
Old Sep 28, 2004 | 01:11 PM
rskrause's Avatar
Moderator
I have no idea if the timing reatrd box has anything to do with your problem, but as far as I am concerned the best method for controlling timing is through the PCM. Just adjust to the desired advance in the 95 and 100kPa area.
Rich
RUENUF
Mar 13, 2016 03:39 PM
Jan 23, 2015 01:13 PM
squarehead
Jan 15, 2015 07:02 PM
Bando
Aug 2, 2002 02:18 PM
