what siex injectors?
Old Jul 7, 2004 | 11:41 AM
JPFAHERTY's Avatar
what size injectors do you recommend I run with a vortech s-trim?
thanks in advance
Old Jul 7, 2004 | 01:07 PM
MEAN LT1's Avatar
Re: what siex injectors?
thanks in advance
What kind of power are you trying to make?
what is your setup?
Old Jul 7, 2004 | 02:16 PM
rskrause's Avatar
Moderator
If you are running the Vortech supplied FMU you should use the stock injector size, unless you are having it custom tuned with a wideband. It will already be quite rich with the FMU, if you used larger injectors without any other changes it would be WAY too rich.
Rich Krause
Old Jul 8, 2004 | 04:34 PM
slomarao's Avatar
I would say either 36's or 42's depending on how much power your planning on. You want them to run at 80% duty cycle.
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
