what should I do for a cam? t76-10/14psi
Ok..im doing the turbo build as you all know(or should know from the posts) and im lookin for a cam. I have a GM847 and I want something smaller..more streetable. I get horrible cam surge but I deal with it cuz it goes really good and sounds bad-***. Since the turbo sound will outweigh the cam sound I want something smaller. Maybe get a lil better gas mileage "out of boost" Something in the low 220's. I dont plan on turning the car past 6000rpms(to attemp to prolong life of engine) so something in the power range of 1500-6000rpms instead of 3k+(like the 847)which is when my cam clears up and starts to pull. I have LE2 ported heads also. Its going to be a 355 with a t-76 and I plan on running 8-10psi on pump gas and 12-14psi on race gas(i care more about safety of the engine instead of making the most HP) and im hoping for 10's. Im keeping the 3.42's as well. Ok well I hope I gave enough info for a base for the cam. Thanks-Mark
Re: what should I do for a cam? t76-10/14psi
I have a similar set-up and I am temporarily going to run a 221/221 .542/.542 114LSA from combination motorsports until I get my heads ported next year. Then I can get a custom grind made to match the head flow.
Cam choices are less important with turbo setups based on the dynocharts and reading I have done online. I'd say grab up 224/224 with a ~112-116 LSA(your choice). Should make good power.
Originally Posted by TransAm396
Lift?
FYI, I believe the 950rwhp LT1 with the PTK kit as running a 218/218 cam...
Where can I get this cam? And it will have better driveability than the gm847?
The more positive overlap, the lopier its gonna be and the less driveable. Here is the formula for caculating overlap:intake dur. + exh. duration = A
A/4 = B
B - LSA = C
C x 2 = Overlap
Example: 224/224 114LSA
224 + 224 = 448
448/4 = 112
112-114 = -2
-2 x 2 = -4 degrees overlap (negative overlap)
Do the same for your GM847 and compare how much overlap it has compared to this cam.
Ok..thanks. So a 224/224 .560/.560 114 is good?Youd think someone would want the lift a lil higher for a blower cam. And I know I they did over 900 with 218/218 thats nuts..I still want it a little bigger..so I can go bigger in the future. What would something like that run me?..
Ok..thanks. So a 224/224 .560/.560 114 is good? And I know I they did over 900 with 218/218 thats nuts..I still want it a little bigger..so I can go bigger in the future. What would something like that run me?
Oh..so 224/224 .560/.560 114 would be good?
Please drop us a PM or give us a call. We have done many forced induction LT1's and have several different custom cams that will work well for you.
