What plugs for my trick flow heads
I did a search but cant find the anwser. What is the best plug for my boosted 383 with trick flow heads , will be running up to 18psi ? and what seems to be the best gap ? thanks
I have used many NGK cold plugs with the single electrode. They all fowled alot. Had to have the AFR correct... always. If I lost a boost intake tube, instant fowling. The ZEX plugs do not fowl nearly as easy. Glad I made the switch. 15psi boost. B.
95chwagon
Jan 13, 2015 09:19 PM
